I am in Edmonton.. the car is hydrolocked. If anyone wants to buy the car for parts let me know asap. I am going to be sending it to pick n pull within the week if nobody wants to pick it up.
email me hoodzy@hotmail.com
1995 gs
eibach springs
kyb gr2 struts
indiglo gauges
front strut bar
rear strut bar
all season michelin pilot exalto's 20,000 left on em
K & N CAI
Hydrolocked my engine :(
- Hoodzy
1995 Creek Mica Blue GS
- Evo_Spec
Re: Hydrolocked my engine :(
err, is it another problem? cause hydrolocking can be solved by simply pulling out the spark plugs and cranking it a few times and then reinstall them and assuming you have no ignition issues it should start right up.
if it is a serious issue then i'd be interested in the strut bars, and tires but i'm in calgary so would you be able to drive them down at all?
Also do you still have the sub box that you have in your car domain worklog?
when I ran into a huge pond/puddle thingey it knocked my timing off. Did you use your car as a submarine? props to you hydro locking it if you did, that's impressive. I have a feeling that it's something different but the car looks great, hate to see it go to the junkers.
- Hoodzy
I had a mazda tech look at it for 2 hours. The entire thing was flooded with water. He said the rods were most likely bent. He couldn't get it to turn over.
- diezzel
Pmd you about your car . Do you still have it ?
- Hoodzy
Yup!
I'll text you today after work.
- diezzel
Thanks . Will talk to you then .
