Trans cooler
- kulluminati777
Trans cooler
Would it be stupid to put a trans cooler on a manual transmission. i keep reading its really un necessary but it wouldnt hurt? I was thinking A manual gearbox doesn't run a pump so you can't fit a cooler unless you have an external pump. Running an external pump would also pressurize the gearbox a bit and you may start having leaking issues. Oil supply would be an issue too, gearbox oil is fairly thick so moving it around through a pump and a cooler would be a problem. Or am i wrong....
- Ryan
Re: Trans cooler
Just don't bother.
No benefit, expensive, and you're just adding weight.
- kulluminati777
- Ryan
Re: Trans cooler
Unless its an ATX... then do bother. an ATX actually generates heat (a MTX basically does not), and will suffer from it.
- kulluminati777
Re: Trans cooler
I was only talking on a Manual trans. Just something to make the car last longer and help the car be more reliable and last alot longer....i was just an idea i had a question about...
