stratman1988 wrote:Been dreaming for a while about a NOS fogger system and poking around the mx3 worklogs and noticed people haven't said too much about how they've altered the interiors of their cars when they installed a nitrous system. So I though I would pose a few questions to the people who have spray on their mx3's:
1. What kinds of safeties/limiters (throttle, rpm, etc.) did you install?
2. Did you install a purge system? Do you need one?
3. What switches/lights did you use and where did you mount them?
4. Where/How did you mount the bottle?
Feel free to tell about all the little details of your nitrous install, what you chose (Brand, Wet/Dry) and your experiences/problems installing and running the system. More pics the better!
1. No safety, just tied system into TPS so when it hit's WOT your spraying.
2. In my opinion purge systems are lame and a waste of time,money and nitrous unless racing professionally.
3. Missile switch on center dash/console, I had a custom plate made up for the cubby hole with gauges and switches.
4. I had a board under the carpet in the trunk, the bottles typically come with brackets which you can screw down, a lot of people just screw them right to the trunk floor with self tapping screws
My experience:
Had a zex dry kit at first on the k8 but the clutch couldn't hold it. They are nice little units tied into your throttle position sensor. Swapped a KLZE and modded the zex kit into a wet system, sprayed a 75 shot on the ZE and it was great. Blew people away at the race track.
Cons: Nitrous where i live is costly, it's also inconsistent when your bottle pressure drops so do your times, yes there are bottle warmers but I don't trust em.
It's initial cost is quite low, but it's the refills that add up... aside from that it's a blast!
