Brake light doesnt like to stay off
cWs306
Post by cWs306 »
Hey, the other day i went to go for a little rip around the block to see if i solved my ignition issue and realized my e-brake light doesnt like to shut off. i searched on here and it came up with the e-brake ground bouncing, so i checked my e-brake n made sure it wasnt bouncing or loose and i tried sticking my finger in the fluid to push around that little magnet or w.e thats at the bottom, didnt do anything. any other ideas on what this would be? crossing my fingers that my master cylinder isnt effed!
Ryan
Re: Brake light doesnt like to stay off.
Post by Ryan »
Um, open the master cyl reservoir and poke a screwdriver down in there. the float sometimes sticks at an angle and triggers the switch. also you could probably top up the fluid.
mitmaks
Post by mitmaks »
how full is your brake fluid?
stepchyld
Post by stepchyld »
Many times that light comes on and stays on, means you're low on brake fluid. If you stuck your finger in it and didn't make a mess, you likely need to top it off.
Same thing happened to me years back in my rs, checked the cable and the switch inside the center console, seemed fine. I checked the brake fluid and needed to add a little, viola!, the light went back to operating as normal. I was relieved!
Mazda came up with a handy way to know when you're low on brake fluid.
Hope that's the case for you!
93 GS, ATX to MTX swap, chrome 16x7, upper strut bars, SRD LCA bushings.
Upcoming improvements: Tokico/Eibach struts/springs, energy suspension LCA bushings
94 RS MTX, Engine swap completed, ALIVE Again!
95 RS ATX, parts car/project X
Ryan
Post by Ryan »
Additionally, brake fluid NEVER requires a top up.
It doesn't wear out, it doesn't evaporate, it doesn't leak out in a controlled manner. If your fluid is low, you need to look into your brakes and likely replace your pads soon. (the volume of fluid that would be occupying the cylinder is now occupying the caliper piston cavity)
If it is suddenly VERY low, you have a leak somewhere.
stepchyld
Post by stepchyld »
True.
I did have to change the front pads not long after that...
check em out
cWs306
Post by cWs306 »
ahhh heyheyhey never thought about the break pads being worn. and no my fluid isnt low thats why i posted. ima go try the screw driver idea, maybe i just washing pushing hard enough.
