Does anyone know where I could get mx3 clear headlight lenses?
Also does anyone know if I can use stock lenses with projector retrofits of it would not disperse light properly?
mx-3 headlight lens/projector retrofit
- mitmaks
- Evo_Spec
Re: mx-3 headlight lens/projector retrofit
they used to be available on ebay but it doesn't look like it anymore.
i don't think you can use the stock lens without it disturbing your light pattern but i know wyldside custom built his and he used the stock lights and polished the crap out of the lens till it was clear so that's always an option.
http://www.mx-3.com/phpBB3/viewtopic.ph ... t=wyldside
IIRC summit racing used to have clear lens covers that you could substitute
- MrMazda92
ninjajim4 is correct.
http://www.summitracing.com/parts/GTS-GT0518C
Those are the cheapest ones I could find with a quick search.
