Question??????
Question??????
Will brake pads bought for a Gs fit the Rs???<BR>And does anyone know what page in the online shop manual is the headlight removal???
Dont want something, that doesnt want you back
Guest
Re: Question??????
Hey to remove the headlites, use a 10mm and remove the two up top of the headlight on the core support, The one on the inside close to the Grille, the two 10mm holding the center of the bumper cover, and then remove the Turn lite of the side you want off then use a long extension with a 10mm on the end and straigt back you will see another 10mm bolt. Now carefully pull the the front grill area forward but Not Hard for there is a metal brace that can bend , and then when you shut your hood the bumper will not line up with the hood and LOOKS CRAPPY, Smamitches!!!!!!!<BR>
