Powder coating vs. high temp enamel (engine bay shiz)
Juans_93_MX3
So my friends and I were having some beers last night and they say that high temp enamel (autozone paint) is the best for decorating the engine bay.
What do you guys think?
Also, if I wanted to do this, do I strip the valve covers and heads to bare metal and than paint? Are there primers I'm suppose to apply?
I have experience painting the exterior of cars but no experience with engine components.
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Re: Powder coating vs. high temp enamel (engine bay shiz)
You never have to strip any paint that's sound unless there's a compatibility issue i.e. lacquer over new enamel paint. Secondly, if after you paint the engine you warm it up the paint will bake itself to a nice shiny sheen IME. There is a self etching primer that's about $18 bucks a can that works well on questionably clean areas.
- mitmaks
Is it acrylic enamel based paint?Juans_93_MX3 wrote:So my friends and I were having some beers last night and they say that high temp enamel (autozone paint) is the best for decorating the engine bay.
- onlytrueromeo
After all my research, nothing compares to powdercoating except anodizing. Paint simply does not have the durability or chemical resistance. It's why I invested in a huge powder coating oven.
mikeinaus
if you want better quality and durability and dont mind spending a bit of money go with powder coat. if you want good results with the possibility of having to redo the work every few years and spend almost nothing go with high temp enamel.
- mitmaks
There is difference from one paint to another paint. You can't generalize every paint. I generally stay away from rattle can paints (acrylic enamel) At least I'd recommend going with acrylic urethane or for a bit more money you can just buy urethane paint. It'll last long and has excellent chemical resistance and UV protection.
- Inodoro Pereyra
You can have fairly good results with Duplicolor VHT. Even when it is rattle can paint, it's almost like a paint/powder coat hybrid, and works really well, if you don't mind the stink while baking it. Other than that, I agree with Onlytrueromeo: nothing beats powdercoating.
Diogenes of Sinope.
Diogenes of Sinope.
Juans_93_MX3
Ok. So how much should I expect to spend to get my valve covers, I/M and heads powder coated?
Cant I get away with buying a cheap used oven, and the gun? Powder coating doesnt seem too much of a hard job. I have done paint jobs on cars before
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Juans_93_MX3
I went on YouTube and found some cool videos
http://www.youtube.com/watch?v=Ql-MFcSc ... re=related
(How to make your own cheap powder coating oven)
http://www.youtube.com/watch?v=OABJHFVAieM
(powder coating basics)
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- MrMazda92
You're PCing the heads?
- MrMazda92
Does this mean you're taking requests?onlytrueromeo wrote:After all my research, nothing compares to powdercoating except anodizing. Paint simply does not have the durability or chemical resistance. It's why I invested in a huge powder coating oven.
- onlytrueromeo
A used electric oven can be had for around $50 in most areas. It has to be electric since I've been told the open flame and gas could react with the process and cause bonding issues. As with painting, surface prep. is key. Also like with painting, you will need a compressor, gun, etc. I find PCing to be easier than painting, at least in regards to getting a consistent product. To DIY, you're looking at about $200 for the gun, oven & powder, more if you need a compressor. The prep materials are more, depending which route you choose to go. Most likely you will have chemical contaminants in both the heads and the covers which will come to the surface with heat.
If you are only looking to do a few pieces, it may not be worthwhile for you to delve into powdercoating. I would then recommend paint or finding a shop to do it for you. (Which will cost close to the price of materials). If you want to do more over time, then you should look at options.
MrMazda92 - Not taking requests, or even able to PC at this time. Still have not run the required 220 in my house yet since I need to run a subpanel to my garage. After my wedding in 2 months, I hope to have enough money/time to get back to it!
I have already PCed a bunch of honda parts and sold them which funded my purchases. I plan to coat every bit of everything in time.
Juans_93_MX3
Yeah, cant you do that?MrMazda92 wrote:You're PCing the heads?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- MrMazda92
I can't see any reason you couldn't, I just don't see it often with KLs. I'd love to see the finished product though! What colors do you have in mind?Juans_93_MX3 wrote:Yeah, cant you do that?MrMazda92 wrote:You're PCing the heads?
- MrMazda92
onlytrueromeo,
Congratulations on your coming wedding! Driving off into the sunset in an MX-3, huh?
Thanks for the heads up, I was being semi-sarcastic actually
I won't spend a penny on beautification until I've hit my performance goals, since all show/no go isn't my thing.
I'd take all go and no show any day.
