Apparently my transmission seal is bad and gave me a greasy clutch on my ZE. The transmission has LSD installed and zx2 gears with a protege 5th gear just so ppm know what's the transmission is.
So not excited about this but the work has to be done right?
Help SuperK with His Transmission Seal Replacement!
Re: Help SuperK with His Transmission Seal Replacement!
Ok here's a starting point just to put the fear of the tranny Gods into you.
http://www.mazdaspd.com/resources/Trans ... ebuild.pdf
Good luck my friend and hey, good idea creating a new post for this.
wytbishop says this has an excellent step by step instruction for rebuilding a trans but I can't see where it is. You supposedly have to sign up to view the forums. maybe pm him. http://www.imazda.com/forums/showthread.php?t=2701
Pictures for phantom grip install, http://www.mx-3.com/phpBB3/viewtopic.ph ... ll#p402218
Did you say you wanted more pics, http://www.mx-3.com/phpBB3/viewtopic.ph ... it=rebuild
Just remembered finding this, not sure if it's relevant now but you can check the part numbers when ordering.
There was a production change on 14.Feb 2002, when the weak parts in the old transmission were replaced by stronger parts (mainshaft,synchros,3/4 gear and more!).
Improved Parts
Speedo Gear: G501-17-341A $9.19
Transmission Lock Nut: F520-17-628 $11.96
Transmission Lock Nut: F521-17-628A $11.14
Oil Seal: F003-27-238B $4.46
Bearings for LSD: G5R0-27-350B $21.15
LSD Itself: GS01-27-190A $448.91
Improved Parts
- Inodoro Pereyra
Nope, sorry. That's the link I was talking about on the other thread. I was registered on that forum. It's dead.Daninski wrote: You supposedly have to sign up to view the forums. maybe pm him. http://www.imazda.com/forums/showthread.php?t=2701
Diogenes of Sinope.
Diogenes of Sinope.
Ya, that's what having a member like you will do to a site.Inodoro Pereyra wrote:Nope, sorry. That's the link I was talking about on the other thread. I was registered on that forum. It's dead.Daninski wrote: You supposedly have to sign up to view the forums. maybe pm him. http://www.imazda.com/forums/showthread.php?t=2701
Hoo boy, am I in for a treat! I'm not excited about this at all. It looks pretty intimidating. Man I wish I had someone that would work with me on this, I would feel so much better. But oh well! Let's see what happens, I dunno if I'll get to it this week or in two weeks, but I'll let you all know more once I start tearing into it!
- Inodoro Pereyra
Yeah. Too bad you're that far away, or I could give you a hand.
My advise to you would be the same I give everybody: take it one task at a time, and document every move (take plenty of pictures), so if you have a problem, you have some back up.
Anyway, if you can, get a J/Y tranny, just in case. Later on, if everything goes well, you can return it.
You bastard...
Diogenes of Sinope.
Diogenes of Sinope.
