KLZE flooding and wont start!!!
- mitchell_jarvis
So i just bought a mx3 with a klze in it, but the car wont start and its flooding itself
heres what happened
the other morning she went out to her car, it started but then just flooded it out...sounded like a 2 stroke engine
loud, misfired
died, wouldn't idle at all.
then started it the next day and it did the same...but then it would idle and sound like a 2 stroke.
its reading codes for fpr and tps, but i replace both tongith and no go. would it matter that the fpr i put on was from a 1.8 and not a 2.5? the 1.8 reads a code kl01 and the 2.5 reads kl02
any help would be great!
heres what happened
loud, misfired
- Ryan
Re: KLZE flooding and wont start!!!
Sounds like you have he plug wires in the wrong order, or the timing is way out.
got a timing light handy?
- mitchell_jarvis
oh the klze what distributer do you use, whats the order of the numbers on the cap.
and i dont have a timing light but can get one easy.
how can i check the timing if its not starting?
mikeinaus
firing order
was the car running fine previously to this problem? if so i doubt the timing is off that bad unless the belt skipped a tooth somehow.
- mitchell_jarvis
That's what we figured, cause it ran fine until the other morning, we think it skipped a tooth from a cold start, thanks
You use the disty that's meant for the year of the car. That way it matches what the ECU is looking for.mitchell_jarvis wrote:oh the klze what distributer do you use, whats the order of the numbers on the cap.
- mitchell_jarvis
my ecu isnt the stock 1.8l one, its the kl36
- mitchell_jarvis
so i just changed the maf and that didnt work, i did a fuel pressure test and it max read 40 psi is that right?
and i heard clicking coming from the back of the motor too, anyone no what thats from?
when i try starting it, it turns over, but doesnt start, it makes slight attempts but then fails to, and after i stop turning the key, it will give a slight jump about .5 sec after. any clue to whhy?
And i talked to my teacher whos a mechanic and he said that if it has good compression then it didnt jump the timing.
and i hear the fuel pump for i dont think thats shot.
someone please help me
- mitchell_jarvis
also just went out and checked the crank sensor and its resistance is only 490. its supose to be from 520-580. would that be the problem?
