Mx3 front brake calipers
DeadMaker
Post by DeadMaker »
I am planning to buy new front calipers cause the existing ones are for trush.
So i have found these.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... OTORS:1123
The problem is that it doesn't say if it is for 1.6 or 1.8v6
Is there any difference on front calipers between the two models?
Black Mazda Mx3 Rs 1997 B6DE
SstennizZ
Re: Mx3 front brake calipers
Post by SstennizZ »
Front? Nope..
Post by wytbishop »
The entire front end is identical from RS to GS.
DeadMaker
Post by DeadMaker »
wytbishop wrote:The entire front end is identical from RS to GS.
This include inner tie rods?
Post by wytbishop »
Probably not as the steering ratio is different. But the steering rack is not part of the "Front End" as far as I'm concerned.
DeadMaker
Post by DeadMaker »
So,in front brakes there is no option available for upgrading from v6.The only option is the rear which i don't think will have a big difference.
After all the front brakes plays the important role.
Ryan
Post by Ryan »
Don't forget that with a rear disc swap you also won't look like a tard if you have rims and drums.
DeadMaker
Post by DeadMaker »
Ryan wrote:Don't forget that with a rear disc swap you also won't look like a tard if you have rims and drums.
LOL.It just a matter of time to get use to it..
Post by wytbishop »
No, there is no easy upgrade for the front. There are a couple of options. One is very difficult but expensive...the other is easier, but very very expensive.
Why not just buy a kit and rebuild your existing calipers. As long as the piston is good and no scratching on the cylinder wall you should be gold. Kits are about $15 at Rockauto.com
DeadMaker
Post by DeadMaker »
Daninski wrote:Why not just buy a kit and rebuild your existing calipers. As long as the piston is good and no scratching on the cylinder wall you should be gold. Kits are about $15 at Rockauto.com
The problem is that when i press the pedal brake the caliper doesn't go behind when the piston goes out.So when the cars goes to stop there is a clicking sound.It's the two pistons that are stuck(Master and slave).I tried to fix it by friction(if i say it correct) the two holes.But i made it worse..The seals were also cut by put in and put out.
