ECU has learning mode
WhiteFinish
Post by WhiteFinish »
Does our ecu have a learning mode ?
I mean, when the battery is disconnected for several weeks. Does the ecu need time to "learn" again ?
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
solo_ryder
Re: ECU has learning mode
Post by solo_ryder »
I have read on a few occasions in the past that if u do the ecu reset, the ecu "learns" for the first 30 min or so. I'm not sure if its true or not as I have never seen official literature on it, but it does make sense.
Maybe probetalk guys would know more? Or someone else can chime in with evidence to support what they say.
Ok its established that our ECU's do learn but that learning is limited to fuel trim, and that's based solely upon input from the O2 sensor(s). You can read about this on any number of Mazda forums. Once you've done any fuel, ignition, exhaust mod that effects performance you should clear your ECU and let it relearn your new system.
WhiteFinish
Is there a certain milage that it should learn?
Worklog click
WhiteFinish
somebody?
Worklog click
the ECU doesn't care about milleage, you just use it, drive it, and it'll adjust and learn the motor. It's more about time than distance. If you just let it sit there and idle, it won't learn much.
kulluminati777
Post by kulluminati777 »
how do u resest it anyway (yes i know im a noob)
Dark_Rider2k3
Post by Dark_Rider2k3 »
disconnect negative battery terminal.
press brake pedal down/hold for 20 seconds.
reconnect negative battery terminal.
burgess
Post by burgess »
Daninski wrote: Once you've done any fuel, ignition, exhaust mod that effects performance you should clear your ECU and let it relearn your new system.
so i recently changed my sparkplugs, should i reset my ecu?
WhiteFinish
No, that won'\t be necessary.
Worklog click
burgess
Post by burgess »
ok just a wonder
