Newbie questions. Car is exremely hoppy and jerky...
Motor mounts? I'm guessing thats whats flexing causing it to shudder and hop around its just annoying- stage 3 xtd clutch any input? I found awr mounts will this fix the problem also my throttle cable is a realy pain to use Thanks
- _-Night-Shade-_
Re: Newbie questions. Car is exremely hoppy and jerky...
Huh? No that actually sounds like a vacuum leak.
mikeinaus
what do you mean your throttle cable is a pain to use? bad motor mounts would cause more shaking/wheel hop then reving problems wouldnt they?
mikeinaus
- Tollis
Learn to use the clutch :p jking.
Yeah sounds more like vaccum probs to me. If you have the stock accordian tubes check all that carefully. Motor mounts would cause more wheel hop/slap as stated above. AWR mounts will make your car a little sexier (internally) but likely wont fix your prob.
Cody
1993 GSZE SE
1993 GSZE SE
If OP is talking about wheel hop and not surging idle then filled motor mounts or AWR mounts will help. If the problem is with idle or engine misfire under acceleration then other solutions are needed.
Its just hoppin around like a pissed off bunny rabbit. It's not a vacuum leak ! Maybe it is. However! when i say the throttle is a pain to use. I'm referring to it binding. Sometimes its sticky sometimes it works great. So basically I'm riding the clutch hard. Stage 3 clutch to I know that will help with it being a jerk-mobile. All of my vacuum stuff is in the clear. It idles great its just when you engage the clutch and try to accelerate. UNLESS your a seasoned pro its basically a pain in the -Insert word here- to drive.
Stage 3 for street use,,,BIG mistake. Is the engine reving smooth just jerky when you let out the clutch. Could be the clutch? Is the clutch broken in yet and was the fly wheel machined before you installed the clutch? Finally look at your front and rear mount and you can see if they're pooched or not.
mikeinaus
that would be your stage 3 clutch and motor mounts. stage 3 has alot more grip and engages quicker then a normal clutch would. try filling your motor mounts or buy a set of awr mounts.
mikeinaus
take a look at your ball joints and see if there is alot of play. mine were pretty fucked and alot of my wheel hop went away when i replaced them.
I fixed all my ball joints inner outter tie rods etc :p prior to this its a fresh swap and mounts are prolly horse ****
could be a cheap clutch. XTD is ebay IIRC... I've heard mixed reviews about these
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
