alarm central locking help
rite guys im fitting my alarm in the 3, got it all fitted apart from the central locking which wires do i have to connect in to. to get the solinoid to work or any advise would be great thanks jon
- umcamara
Re: alarm central locking help
There's no lock actuator in the driver's door. You need to add a lock actuator to the driver's door ($8 part, may take you awhile to get your first one installed properly), then you have to wire up two relays for reversed polarity.
Passenger door lock follows whatever the driver door does.
