Clutch release bearing AKA throwout bearing
im2bad4ya
Post by im2bad4ya »
so I need to replace this bearing, presumably along with my clutch. I got a nice deal for a Exeddy clutch kit for my 4cyl for $46 off amazon.com. Anyway, I wanted to know if the throwout bearing comes with the clutch kit, or is it something I have to get separately?? I ask because there a few names for this bearing, and I'm not exactly a mechanic. I checked the workshop manual and couldn't find a reference to either one. The only place I've been able to find the bearing is from a Mazda dealer, which is charging $25, but before I get that, I want to make sure it doesn't already come with the clutch kit.
-1992 MX-3 RS w/BP Swap Tropical Emerald Metallic "Lucky" 2005-2012 *REST IN PIECES*
Worklog: viewtopic.php?f=46&t=78176
-2003.5 MAZDASPEED Protege #882 Blazing Yellow Mica "Lemon Drop" 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 Spicy Orange "Debbie" 2014-2015 SOLD!
-1980 Toyota Corolla Green 2014-present
-2002 Lexus IS 300 Solar Yellow 2015-present
Ryan
Re: Clutch release bearing AKA throwout bearing
Post by Ryan »
normally clutch kits come with a TOB. Its the big one that the clutch for presses on to disengage the clutch.
The other one you'll want is... ah, what do they call it... a pilot bearing?
im2bad4ya
Post by im2bad4ya »
Kit includes:
1. Exedy Pressure Plate
2. Exedy Clutch Disc
3. OEM Release Bearing
4. OEM Pilot Bearing
5. Alignment Tool
so I guess the 'OEM Release Bearing' and the throwout bearing are one in the same???....if it is, I'm good :-)
Ryan
Post by Ryan »
yup, its good.
Return to “Transmissions”
