[FS] Mass KL and MX-3 Parts
Hey I have some stuff I will never do anything with so I am selling it. I am located near Zanesville, Ohio. Local pickup is preferred but I will ship if you pay for it.
KL Intake Manifold - $20
- Includes everything minus Fuel rails and injectors
KL AC Compressor - $20
KL Auto Trans Starter - $20
KL Alternator - $30
KL Cam Pulleys (Painted Blue) - $10
KL Fuel Rails - $15
- 2 Sets
KL Oil Pan - $10
- I have 2 of these
MX-3 Tails Lights - $20
- 1 pair of stock, 1 pair of niteshaded
MX-3 Radiator support - $10
Full MX-3 Interior - Let me know what you need and Ill give you a price
- All black and in good condition
MX-3 Turn Signal housings - $10per pair
- 3 pairs
MX-3 Side Markers - $10per pair
- 3 pairs of red and 3 pairs of amber
MX-3 Drivers Side Auto Seatbelt w/Motor - $10
NGK Spark Plug Wires - $20
- SOHC 1.6 MX-3 Engine
KL Crank Sensor - $10
KL Coolant Lines - $20
- All Metal Lines including thermostat housing and thermostat
- 2 Sets
Timing Belt Pulleys - $20
- 2 Sets
Timing Belt - $20
- Like New, but used for maybe 1k miles
Red Top Nissan Injectors (270cc) - $20
- 2 Sets of 6 along with top hats
Nissan Injector Plug N Play Harness - $30
- Made so that your stock wiring harness will plug directly into the Nissan Harness
- Heat Shrink and wire loom used
GS Headliner w/ Sunroof (Tan) - $10
Front and rear brake calipers - $30 a pair
Passenger and driver side control arms - $20 a peice
GS Crossmember - $20
Shift linkage (both rods) w/ short shifter - $30
Power steering rack - $30
Steering column w/ ignition and key - $50
Ill add more as I find more parts. Let me know if you are interested in anything and we can work something out.
KL Alternator - $30
KL Fuel Rails - $15
- 2 Sets
KL Oil Pan - $10
- I have 2 of these
- 3 pairs
- 2 Sets
- 2 Sets
Timing Belt - $20
Re: [FS] Mass KL and MX-3 Parts
Dibs on the oil pan and A/C compressor, PM sent.
I'm interested in the K8 ECU...1 set of injectors and fuel rail and some interior parts - PM sent
Not sure if it can be chipped its from a 92, and yes i have one of the sets of rails and injectors assembled. And I do have one of the garment clips, it is tan.
- _-Night-Shade-_
All PM's replied to, I have an almost complete 92 GS for parts if you need anything else I might have it.
where r u located? Might be interested in the seats.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Sorry, I am using the seats.
- fowljesse
I want the pistons!
$30 shipped my friend, Ill PM you the info.
- DeepBlueMX3
- PATDIESEL
are the heads DE or ZE? asking because the difference in the valves and cams (if they have those installed)
DE, They have the same size intake and exhaust valves. No cams come with the heads but I do have a set of KL01's.
Everything everyone bought should have went out today if not before. Thanks. Still need to get rid of the rest of the stuff that will never be used.
- SteeleMX3
pics of interior (dash mainly)? I will grab the dash vents off you if they are the ones with the wheelie thing to tilt them.
cheers.
cheers.
1992 Mazda MX3 Precidia GS-KLZE :: Rockin' my world since 2009
viewtopic.php?f=46&t=72989 ---> Workloooogg
