KLZE Turbo need to reroute my intercooler pipes help please
wohpony
Post by wohpony »
My intercooler pipes hang to low and hit everything in the road I need to re-route them and was wondering if someone could post photos of how you have yours.
1993 Mazda MX-3 GS KLZE
hgallegos915
Re: KLZE Turbo need to reroute my intercooler pipes help please
Post by hgallegos915 »
How are your pipes laid out? What kind of intercooler?
I have a talon sidemount and everything fits right in on the side.
-hec
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
mine is an RS, but it might be able to help out.. after all they have to cross the bumper at one point.
http://www.mx-3.com/phpBB3/viewtopic.ph ... 4&start=30" onclick="window.open(this.href);return false;
johnmx3ze
Post by johnmx3ze »
my piping is alot lower then yours and im dropped and i dont hit anywhere…
do you go offroading with it!
hppwdn
Post by hppwdn »
Here's an old pic of my pipes from when they were first redone. I used to have a problem with mine being too low as well.
DiaMagus
Post by DiaMagus »
Id mount the intercooler higher and put brackets to brace all of the piping. get them tigged on and bolt them to the frame..
But really the sending pipe should rap around behind not above I think
DiaMagus
Post by DiaMagus »
Isnt that flimsy as hell? Im working on mine now I was gonna tig a brace behind the latch
hppwdn
Post by hppwdn »
Not sure if you were referring to my pic but I think you were.
DiaMagus wrote:Isnt that flimsy as hell? Im working on mine now I was gonna tig a brace behind the latch
It's far from flimsy. It actually doesn't move, it's tucked up under the radiator support nice and snug.
DiaMagus wrote:Id mount the intercooler higher and put brackets to brace all of the piping. get them tigged on and bolt them to the frame..
Wrapping the piping around runs it either thru the hot engine bay or under the frame rail causing a big ground clearance issue. My first set wrapped around and it was really annoying. This way all the pipes are tucked in behind the bumper as far away from heat sources as possible and don't cause any ground clearance issues.
johnmx3ze
Post by johnmx3ze »
hppwdn wrote:Not sure if you were referring to my pic but I think you were.
i really like the way you did it! is that alluminium piping?
heres mine it suck but i will be redoing it soon! cant really see but it goes under/ behind the intercooler!
DiaMagus
Post by DiaMagus »
Thats pertttyyy. Hey what bumper you running I ripped that brace out behind
Thats smexy you run ground effects? Thats a nice setup
johnmx3ze
Post by johnmx3ze »
yeah i have a body kit…
DiaMagus
Post by DiaMagus »
Looks alot different than stock .. Is good install. did you modify the flange? to fit the turbo
Return to “Forced Induction”
