hi guys, i had a quick search about and came up short.
does anyone know if it would do any damage if i ran a higher ampage battery, rather than the 40Ah thats on their as i have a 60Ah sat in the garage, and the top of mine has started to melt!!!
batterys !!
- Inodoro Pereyra
Re: batterys !!
As long as It's a 12V, nothing will happen. Just make sure it's not taller than your stock battery, and if it is, check you have enough clearance to the hood that it won't touch the positive terminal.
Diogenes of Sinope.
Diogenes of Sinope.
Re: batterys !!
thank god for that. hopefully it will be better against the cold weather we have over hear at the mo
