urgent help needed v6
jon_young
Post by jon_young »
rite, done the clutch. put it all back together,
can shift through the box fine with engine off!
turn her on put the clutch down and it wont go in to ANY gear at all
but if you put it in gear start it with clutch down, and you can get the biteing point.
HELP!!!!
clutch is fine no air at all
i have removed starter and when the clutch is pressed you can see the pressure plate moving will the springey bits
any ideas guys
Newfie_dan
Re: urgent help needed v6
Post by Newfie_dan »
I would say clutch alignment issue, or flywheel is warped somewhat as 2 distinct possibilities. Secondary to that would be shift linkage not working properly if you did not have any issues shifting prior to clutch replacement then I would be looking at clutch alignment if your sure that the clutch hydraulic line is air free. How does the clutch pedal feel for pressure?
Return to “Transmissions”
