replacing thermostat on MX3 GS, fml...
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
SteeleMX3
Post by SteeleMX3 »
I realised it wasn't worth it to take my 92' MX3 GS into a shop to get the thermostat replaced when i was quoted $200 and I bought the thermostat from partsource for about $15. So I went to replace it and fml, it's covered by 500 wires. anyone have suggestions on how to do this simply?
cheers.
1992 Mazda MX3 Precidia GS-KLZE :: Rockin' my world since 2009
viewtopic.php?f=46&t=72989 ---> Workloooogg
umcamara
Re: replacing thermostat on MX3 GS, fml...
Post by umcamara »
Check the online manual.
Click Here
'98 BMW 328is M-Tech
Feedback Thread
solo_ryder
Post by solo_ryder »
Hahaha FML
Just unplug all those shits and move em outa the way. You cant really confuse the plugs up cause they only fit one connector.
Ryan
Post by Ryan »
If thats a FML moment, your life must rock.
_-Night-Shade-_
Post by _-Night-Shade-_ »
Ryan wrote:If thats a FML moment, your life must rock.
I second that :)
onlytrueromeo
Post by onlytrueromeo »
This is really easy. I would suggest draining/flushing your cooling system while you're at it, since you will need to refill up a bit after replacing it anyway.
Take the plug out by the passenger side of the radiator, through the bumper. Drain all the coolant so you don't get it all over your engine bay.
Replace thermostat, then follow procedure for refilling cooling system. Make sure to burp air bubbles.
Should take you no more than a few hours to do everything, make sure you have antifreeze before you drain the system as you can't drive to pick it up with none in the car!
Flyer
Post by Flyer »
solo_ryder wrote:Just unplug all those shits and move em outa the way. You cant really confuse the plugs up cause they only fit one connector.
That sounds like a challenge to me!
Return to “Engine Electronics/Tuning”
