Ok so I bought a bosch disty cap from rockauto.com
It's exactly the same as the old crappy cap but it won't fit on the disty properly. Basically, the old original cap fits nicely with the rotor on the disty but the new one doesn't. On the old cap, there is a little button in the middle and it pushes down slightly. On the new bosch cap, it does not push down at all.
It seems this center section is pushing on the rotor and not allowing the cap to fully seat against the disty. I might have to sand down the center section of this cap or something. I can't send it back to America, it's not worth it.
Anyone else ever have this issue?
Stupid crap bosch disty cap
1995 Eunos 30x KLZE
- vansolrick
Re: Stupid crap bosch disty cap
The ones I've used all push a little. Maybe it's designed specifically for Bosch rotor buttons?
Hmmm they shouldn't be allowed to sell it separately if that's the case. I'm gonna try grinding down that middle part a little at work tomorrow.vansolrick wrote:The ones I've used all push a little. Maybe it's designed specifically for Bosch rotor buttons?
1995 Eunos 30x KLZE
Do make sure the rotor is completely seated on the distributor shaft. The cap may be defective, but if it is you're better off returning it than modding it.RX8SE3P wrote:On the old cap, there is a little button in the middle and it pushes down slightly. On the new bosch cap, it does not push down at all.
Yeah the rotor is definitely seated fine. I have no choice but to try and mod it since I live in Australia and postage back to America will cost more than the cap itself. I hate when this stuff happens.davmac wrote:Do make sure the rotor is completely seated on the distributor shaft. The cap may be defective, but if it is you're better off returning it than modding it.
1995 Eunos 30x KLZE
