Painting fuelrails
- WhiteFinish
Painting fuelrails
Hi Guys,
Is it possible to paint the fuelrails without take the injectors/o-rings out ??
I want to paint it professionaly, so after painting it the temperature will reach 90 degrees celcius (200 fahrenheid)
The reason is that I broke 2 injectors when I wanted to take them out last time.
- Ryan
Re: Painting fuelrails
I'd go with 'not easily'
Just be super careful... wiggle and twist and pull, all very gently.
- mitmaks
you can always get them powdercoated
- solo_ryder
I got mine powdercoated, recommended.
However, if u wanna paint em, just rattlecan em or if u wanna get it done professionaly for whatever reason, take the injectors out with a pair of big pliers and wiggle em.
When putting em in use some oil to lube the oring and squish em in
- WhiteFinish
I can have them painted at my work for close to nothing, so that's a better option then powder coating.
Can I still use the O-rings after getting the injectors out?
Would WD-40 help with getting them out?
- mitmaks
what kind of paint are you guys using?WhiteFinish wrote:I can have them painted at my work for close to nothing, so that's a better option then powder coating.
- solo_ryder
Yea, you can reuse the orings. As long as they arent cracked or deformed they should be fine. Yea, WD40 should work to put em in as well.WhiteFinish wrote:I can have them painted at my work for close to nothing, so that's a better option then powder coating.
please get an oring kit if you have the 6cyl. it's super cheap and it's a set for all six of them for a few dollars.
Also if you put something round on the spray end of the injector, then hit it out, it doesn't damage the injector and they pop out.
- solo_ryder
and were would you get those? I checked parts stores locally and they didnt have nothing when I looked (first time before taking them out)
I had no issues reusing the orings on any of the injector rails I worked on. The orings were still soft and in great shape
- WhiteFinish
My O-rings are 6 months old (tops)
My company builds touringbusses, so we paint those inhouse and we can use the painting stuff for personal use.
Rockauto.com
FEL-PRO Part # ES70713 {Set}
$5.71
that's six bucks for 12 o-rings. big one, little one, six each.
$5.71
