Diagnostic Box Help
PTCS
Diagnostic Box Help
Post by PTCS »
Just put the engine in ... the mazda mx3 v6 1.8... have jumped the diagnostic box. Initially there was one code on the box code 12. .. throttle position sensor... I tried centreing the sensor... still coding... now there is a bigger problem.. everytime i put the car into gear.. the engine rpm revs up from 650.. to 1300 rpm... does anybody know what would be causing this... as well now instead of one code... 12.. I have a number of different codes as follows: 16, EGR Position Sensor, 17 Feedback system or closed loop system right syde.. 11.. Intake air Thermo Sensor Dynamic Chamber and 4 Distributor... The only real noticeale problem is, again, when the car is put into gear the idel moves up from 650 rpm to 13-1500 rpm.. take it out of gear (5 speed manual) and the rpm returns to normal.. does any body have any ideas re: all the codes and also whats causing the increase in rpms when put into gear..
thanx
ptcs
umcamara
Re: Diagnostic Box Help
Post by umcamara »
The TPS is NOT set by centering it. There's a procedure in the online manual involving a feeler guage and an ohm-meter.
Intake air thermo-sensor should be an issue with your VAF.
Not sure about the rest.
'98 BMW 328is M-Tech
Feedback Thread
PTCS
Post by PTCS »
I apologize for my ignorance.. you say VAF.. I would assume this as something to do with the variation of RPMS when put into gear.. also could you describe the thermo sensor and its location so that I can take a look at it and possibly repair it...
ptcs
umcamara
Post by umcamara »
The VAF is the volumetric airflow meter. It's a round black plastic piece that is connected just after the intake airbox. It'll have a wire harness connected to it, and is worth a stupid amount of money new.
Maybe somebody else can confirm, because I'm more familiar with a MAF, but I believe that like a MAF, a VAF will have an intake air temp sensor inside of it. I apoligize if this isn't correct.
This part generally isn't repairable, and usually involves replacement.
Feedback Thread
93vtecklr
Post by 93vtecklr »
I went to a wrecker and bought another vaf for about 80 bux, somewhere around 800 for a replacement.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
Mad Cow
Post by Mad Cow »
93vtecklr wrote:I went to a wrecker and bought another vaf for about 80 bux, somewhere around 800 for a replacement.
Wow you got ripped off, I paid $40 for mine...
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated :lol: -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
93vtecklr
Post by 93vtecklr »
At the time, it was the only v6 mx3 at a wrecker in central alberta, It was for my last mx3. I had the crazy idle problem before I knew of this site. Mazda told me it was the vaf, you know how stealerships can be..... You have to replace the most expensive part......
