I have used the search at the top of the page and to no prevail.
Just a quick question.
Im looking to swap my 93 euro style dash to a 94 bubble style and was wondering if it can be done. If so what problems am I going to have with doing the swap.
Thanks
93 to 94 Dash conversion ?
93 MX3 b6 auto
94 MX3 b6d 5spd (RIP) - Parts car
B6D stripped and looking to boost. Possible?
Re: 93 to 94 Dash conversion ?
I'm not trying to sound like a prick, but the search did work. Just like when you search google, sometimes you have to adjust your query. Try 94 + Dash Conversion, there is multiple entries in worklogs all over this site. I know of a few members that have done it.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
- onlytrueromeo
Its not impossible, but it is difficult. Nothing lines up. I was successful using the 92/93 rebar that is in your car now w/ the 94 dash. You can attach the dash with 2, yes 2 screws. You will need to custom fit the vent lines form the 94 dash, and I actually used 3" dryer vent line for the driver side left vent.
Also the HVAC controls are different, so you need that.
You will need to cut some of the metal rebar for the 94 dash to fit right, and bend it in other places. The only way to know what to do is to try it.
Once its all screwed in the car its solid, but I'm still working on getting it to line up 100%.
You will also need to splice wires for hvac, a/c, interior light dimmer and the warning lights (unless you swap the warning light switch from the 92)
I was searching the wrong way. I was looking for 93 to 94 dash conversion.
oops
Cool lots of work lol
Thanks for the info
Thanks for the info
93 MX3 b6 auto
Yea... a search would come up with alot actually....
Heres mine.....
Badda Bing... Badda Boom...
Don't ask me how I did it... it's not simple all the wires are different and can not be screwed around with it needs to be done right since you need it all to work! Mine took 2 weeks to get it right... No problems yet!
Heres mine.....
