Turbo Charging b5 dohc
alpaccino
Post by alpaccino »
good day all, i'm a newbie on this site, i'm doing a modification and am seeking your advice and help.
i have the b5 dohc engine which i want to boost, but i am wondering if 8psi is too much. i want to boost it with out modifying the stock internals.
also does anybody know where i can get a complete turbo kit (with the manifold)?
alpaccino
Re: Turbo Charging b5 dohc
Post by alpaccino »
Has no one ever boosted a b5 dohc before
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
the 1.6... yes
1.5.. not that I know of
There is a j-spec turbo out there, I think it's a b6 tho.
alpaccino
Post by alpaccino »
isn't the b5 a great engine to turbo charge?
is it possible to use the turbo kit for the b6t on it.
hotsiit
Post by hotsiit »
My guess is not many people will know how well the b5 motor takes to turbocharging, as most members are from North America ( USA & Canada), and the 1.5l b5 was not an engine choice here.
I can tell you my stock 1.6L SOHC b6 ran for years at 9psi with stock internals.
Welcome to the forums!
:D
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
boosted_bullet
Post by boosted_bullet »
SWAP!!!!!!!!!!
chicks dig the rice!
-bullet
B5 is suppose to be a very strong engine.
alpaccino
Post by alpaccino »
i was of the same impression so would you advice me to boost it with 8psi (stock internals). i just wanted to know also which manifold could work.
RS_OBD'oh_2
psi may not be the correct term here. What turbo would you use? It should handle 8 psi on a smaller turbo.
osargeant
Post by osargeant »
I think people need to stop thinking of terms of psi and look at the specs of the turbo, 8psi on a T3/T4 is not the same as 8psi on a small T25. The key thing is proper tuning of ignition timing and fuel, I have a stock engine and have run up to 14psi on occasion.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
Hot_Wheels
Post by Hot_Wheels »
wanst the 1.5 in the festivas from over seas?
marcdh
Post by marcdh »
go onto club323f.com, there's a UK guy has ghetto DIY turbod his 323F BA/Lantis with the Z5 engine. I think he's shooting for 10psi on his t25 turbo. Check it out: http://www.club323f.com/club323f/forum/ ... 63&start=0
View Worklog
Post by Josh »
the 1.6L is a overboared version of the 1.5 which all derived from a 1.3L in the 80's. so all inturnal parts should be the same. manifolds might not be however.
osargeant
Post by osargeant »
Manifolds are the same, you can use the GTX manifold on the 1.5 DOHC since guys here in Barbados have done it on the Mazda Lantis with the 1500cc engine. Actually most of the parts between the 1500cc and 1600cc Mazda engines are identical.
10secSim
Post by 10secSim »
didn't the b5 have a variable valve timing system of some kind...There's a guy in cornwall, on who has a mx-3 with a b5 in it...that's what he said :roll:
B6 1.6L DOHC, CAI, custom intake mani. with internal velocity stacks, 65mm thottle body, probe 4-2-1 header, custom 2.5" high flow exhaust, Centerforce dual friction, MS2, MSD 6A, Tokico struts, EIBACH springs.
http://www.cardomain.com/ride/2443642" onclick="window.open(this.href);return false;
Return to “Forced Induction”
