so atm i believe that my synchro has gone bad and soon i will be needing a new tranny.
but i was also thinking that maybe my clutch needs to be bled.
could this be a problem that would cause shifting to be very hard? most of the time i have to double clutch just to change gears
input appreciated
hard shifting
- muttpower
Re: hard shifting
how's your shift bushings???
1992 MX3 GS (My Project Toy)
K8DE, see web site...too many mods to list, but still growing.
2006 Dodge Durango (The Family-Mobile)
Every time you race a Honda Civic, a kitten kills a retard.
Re: hard shifting
couldnt tell you ill have to take it apart and look at it.
when i get a chance ill do that and post up on here.
Re: hard shifting
May just need to be bled, but may also need to be replaced. When the clutch gets really worn it doesn't disengage fully and it gets harder and harder to shift.
- Inodoro Pereyra
Re: hard shifting
Before you open up the tranny, take a good look at the clutch pilot bearing, and the end of the tranny input shaft, where the pilot bearing fits. If the input shaft is worn out or the pilot bearing busted, shifting can become almost impossible.
Diogenes of Sinope.
Diogenes of Sinope.
