(wtb)m62 supercharger pulley
i am looking for a pulley for a clutched m62 supercharger if anyone has one they want to get rid of it please let me know a price with shipping to vermont.i cant find a place to buy just they pulley.
						- solo_ryder
Re: (wtb)m62 supercharger pulley
Try probetalk or check eBay periodically. I doubt anyone here has one
i didnt know if anyone would and i am putting one on probe talk i have the blower mounted in the ac location all i needed was a oil filter relocation kit and yes it is a VERY tight fit but i did it i just need the pulley , and yes i know that pulley on our motor only gives three pounds of boost but  i want to get it boosted and then upgrade when i have more money but three pounds on my de should put me at ze hp level and i got the blower for free with only 10k on it and i can use it for now with just a fmu till i can get megasquirt , injectors , and a new pulley but im good with 30 hp for free.
						- solo_ryder
Ok, well noone asked for that info, but ok.
I know that the SC would fit in the AC location as I almost did it at one time. Try PM'ing Aldorin on probetalk, he can make custom pulleys for the M62 and also make customer overdrive pulleys for the K series motor (the route I was gonna go)
Order the oil kit from here:
http://www.mbxmotorsports.net/
Decent kit. The guy who bought my last MX is still running it as I installed it. I did however need to make a cork gasket as the OEM gasket did not seal well enough, so maybe buy some cork gasket maker and stencil it out with the OEM supplied gasket.
i have the kit and its already been mounted i took it off as i dont have the right pulley yet and i told you the other info so you could know why  i was looking for the stock pulley instead of a smaller one
				MX3Extreme
I am pretty sure i have one for you but i will double check first today. I have a supercharged jackson racing integra gsr aswell with upgraded boost so i may have the stock pulley?
ill let ya know
MX3EXtreme
						ill let ya know
MX3EXtreme
thanks that would be great
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
				MX3Extreme
Hey, have a charger pulley but my charger is a m45 not a m62 so i am not sure if it will be the same bolt up size or not?
MX3Extreme
						MX3Extreme
These should work.
https://www.4x4parts.com/catalog/index. ... th=367_385" onclick="window.open(this.href);return false;
