3 cylinder turbo.
projectzemx3
3 cylinder turbo.
Post by projectzemx3 »
has anyone ever ran a small turbo off just the front 3 cylinders???
anybody have thoughts on this? i think its a good idea especially for someone who is only looking to run 4 or 5 psi.
not only would it be easy to make yourself. you could locate your turbo up around the ac spot and you could cut your stock y pipes front bank pipe and have a piece welded in to connect from the turbo.
this might be something worth trying..
NEED PARTS INSTALLED? PM ME!
Hot_Wheels
Re: 3 cylinder turbo.
Post by Hot_Wheels »
i think it was the pontiace firegly? wasa trbo 3 cylinder
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
welding a cast iron manifold does not work very well. If you want low psi, get the correct spring/actuator for the wastegate and you're done.
BuGS
Post by BuGS »
i doubt anyone has done it, but if you are looking for something easy, just go rear mount. I know everyone on here says they are dumb, but I have talked to 4 or 5 people that have actually done them, and they say they actually run good if you get the right setup. Big exhaust wheel, small compressor, and you won't have any lag after the exhaust warms up.
Ryan
Post by Ryan »
I was about to ask a dumb question, but then I got it. You're running 6 cyls on the turbo from the exhaust from 3 of them, right?
buck_racing
Post by buck_racing »
lol out of all topics on here i find this one. i just sold my turbo 3 cylinder to the crush yard.
projectzemx3
ya so i talked about this idea with some people who are familiar with boosting and basically i think running a 3 cyl turbo off a v6 would burn out some valves rather quickly due to uneven back pressure.
Ryan
Post by Ryan »
Huh?
Then would a full 6 cyl turbo not burn out all of the valves? Its not like the valves talk to eachother and decide to burn out based on unfair treatment.
Although I could see how the pressure on 3 vavles would be greater than over 6.
If thats a bigdeal, get some nice valves...
projectzemx3
nah it was a stupid idea anyways. if your gonna boost it then you might as well just use all 6. exhaust pressure would be off for spooling. your better off larger turbo with 6 cyls for sure.
hgallegos915
Post by hgallegos915 »
Just use all six, its easier to use the manifulds that it came with, im not sure if anyone has used the new style piping that lets you not cut the crossmember here?
Now,i am running a hot side ar.63 and a cold side ar.48
and this turbo runs out of breath at 5k rpms
a hot side ar.48 and cold also ar.48 will defenetly choke at high end even at low psi.
as thats what was happening to me.
-hec
marcdh
Post by marcdh »
Sorry to further digress, but Hector, is that the new style require using the stock log manifolds?
View Worklog
Mnemonic
Post by Mnemonic »
why would you do this when the hot pipe are so freaking cheap on ebay?
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
hgallegos915
marcdh wrote:Sorry to further digress, but Hector, is that the new style require using the stock log manifolds?
No its a different type of pipe that was on sale on a BB on probetalk a while back. I dont think anyone tried to fit them on the mx3. The wastegate would sit in front of the radiator where the fans go.
-hec
Return to “Forced Induction”
