Rim size + offset help
solo_ryder
Post by solo_ryder »
Question is, will a 16x8 +32 offset fit with 215/45/16. I can manage with a small fender roll, but does it fit? Smaller tire?
I know 16x8 shouldn't be a issue as I have a buddy running 17x8.. If I have to run small spacers that is ok, I am just worried about fender clearance considering how low I am
yence
Re: Rim size + offset help
Post by yence »
depending on your rear camber, you might need a slight roll on the fenders, but it should work fine. If you have coilovers though, the amount of space left towards the struts will be limited (in the rear), so you wont be able to run a lot of neg. camber in the rear.
1995 noble green MX-3 RS (sold)
1994 clear white MX-3 GS (r.i.p.)
1987 white RX-7 FC
1993 mighty grey MX-3 GS
