So the middle console in a 1994 mx3 is there any other type of midle console that can re place it?
(sorry if this is in the wrong spot i did not know where to put this)
middle console
Re: middle console
ummm well why do you want to replace it?? Is it to high or just in the way? You can always make anything fit but will always need a little work!
Re: middle console
well i just want to be unique and what type of change could i do to it?.... I was thinking about making a fiberglass shell of it and put that in... but i am not the most experience in any type of field
Re: middle console
Well if you want to be unique you gotta think of something you want and just go for it.... I will eventually put 2, 5 inch mids facing outward in fiberglass. It's not that hard there are some walk throughs on Youtube.
Re: middle console
Make the bottom base shell of the console. After that, it should be cake. Just build the rest how you'd like.
I don't think there is any console swaps for our cars.
--- K8 was my gateway drug.
Re: middle console
so take out the mid console and then build a base and just do it that way?
