tranny/diff question--urgent
kab-rst
Post by kab-rst »
i have the possibillity to buy a lsd diff from an oem g-serie lsd
''LSD 26 spline de Mx-6 KL-ZE E-GE5B (62 450km Front Clip).''
i have to use my ring gear since it dosent come with it, i have plenty here,no problem,
Image[/quote]
the question is, would it fit a bp tranny, since it's all g-series, and if it does fit in(wich i dont even doubt) would stock axels fit in? i think bp's allready are 26 spline right?
i would buy it right now, i just need a confirmation
96 rs-t mx-3, 12.62@114
u have the Zoom Zoom feeling?
kiwimx3
Re: tranny/diff question--urgent
Post by kiwimx3 »
It looks like my MSP LSD.
It will fit into any G serise case, you might have to clearance part of the case with a Die
grinder, ( I did )
Yes they are 26 spline, the only minor issue is the circlip snap ring on the axle of the
gearbox side, they are not equal lenght shafts ( MSP ones certainly )
see if the guy will supply the gearbox stub shafts...
kiwimx3
Post by kiwimx3 »
Update.
Had a look at my spare MSP Diff, mine is rather different ie can't see through it
also the back of the diff head does not have the ribbing like that one does.
If the vendor claims its a LSD I guess your going to have to take his word on it
As to fitment. still not a issue size wise as all G series cases are the same.
( ie rod change cases, cable change are a different kettle of fish in a few parts )
Return to “Transmissions”
