current
Fresh rebuilt BP-T with less than 15k miles on it.
miata tubular header
garret t3 turbo
38mm tial wastegate dumped to atmosphere
2.5 inch catless turboback
apex-i n1 exhaust
bp performance fmic
ported gtx intake manifold
bpc8 323 gtr ecu
rx7 460cc injectors
msd 6al ignition box
msd blaster 3 coil
short shifter
poly bushings on sway bar, shifter, motor mounts
ground control coilovers
tokico s/r struts
v6 rear tie bar
gtx strut bar
rear strut bar
arp extended wheels studs
walbro 255 fuel pump
installing bp_performance fmic kit + synapse bov
stripped the interior to get it ready for new carpet + i installed momo hub and nrg 11.8" steering wheel
installed spyder auto projectors + hid's
got a new harness came with 4 wire o2 and i did a 4 wire tps swap
323 gtr ecu waiting to join the 460cc rx7 injectors along with a gtr vaf rx7 vaf
my t3/to4 waiting for a rebuild to go in when i get the etd manifold
awr f&r mounts waiting to go in
i guess that is it for now i will add more when i get more work done
