PCV system and turbo dilema (YES I searched)
				hgallegos915
So Im trying to figure out why all of my engine core plugs are leaking!!
I stopped the cam cores from leaking, I installed a new front main seal and it started to leak immedieatelly?!
My read main seal leaks drops to the clutch.. I got the seal now.
Now can this be because I have my pcv system completely vented
but if I connect it.. wont I be boosting the crankcase??
my friend in his boosted de mx3 has blow 3 engines... he has the pcv valve connected properly to the im but he i venting the other part of the pcv.
I on the other hand have not blown any engines.. just seals.. what gives?
so are we supposed to have the pcv or not? for boosted cars.
-hec
- johnmx3ze
Re: PCV system and turbo dilema (YES I searched)
i want to know that too...
							mx-3,  KL turbo (tooo much to list) yeah its boosted!
The PCV valve is a check valve. It only allows pressure out of the case...not in. So no you would not be boosting the crankcase. If you're blowing a lot of seals there's a good chance that your rings are gone.
- RS_OBD'oh_2
you want to equalize the pressure in the crankcase.  Get a catch can.. or 2.  It will remove the oil from any blow by and reduce the pressures blowing your seals
						- Josh
If your worried about, buy the PCV off of the 88 GTX, the B6T.
Did you get the seal in all the way, i know its a dumb question BUT it could happen, maybe a dent in the corner of the seal or cockied.
- cjthor
Ive been running a pcv valve since day one and never had a problem.....but I am using the one that came with the b6t
							Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- Josh
from what i recall is the valve from the B6T is stiffer, where the stock B6 or BP PCV will have a tendancy to prematurly wear out.
				hgallegos915
so how do you v6 guys have it connected?
pcv valve to manifold connected on the valve cover.. what about the front hose in the valve cover and the rear hose?
-hec
- mazdax3speed
i have the pcv valve in the valve cover (just a NA BP pcv), but no lines on it and a breather filter on the side of the valve cover, i haven't had any problems, but i would like to run a vented catch can.
							Orange 95' BPT GT28r, MSII on the way
				hgallegos915
OH I get it now, thats how imma set up minethen.. imma get a millenia s pcv, and put a filter on the back one and front one. Thanks
-hec
