... And every cylinder pegged 190PSI EXACTLY on each cylinder.
Not bad for my little 130k B6.
However, I noticed that two spark plugs were crusted white. Looks like I prolly should look into getting my injectors cleaned and rebuilt.
That, and I am still chasing a mystical oil leakage from somewhere...
Oh, I am just talking to myself outloud, then typing it out, since you can't actually HEAR me talk to myself.
But I am proud of my little b6east
SuperK did a compression test on his B6...
Re: SuperK did a compression test on his B6...
From the workshop manual:
1.6L B6 Compression:
1,324 kPa
13.5 kg/cm^2
192 psi
I'm hitting just about perfect on every cylinder
1,324 kPa
13.5 kg/cm^2
192 psi
wow, I really need to get me a compression tester and see what i'm running at. That's impressive superk
Very nice. I did a test on mine around a month ago and I was at 150psi across the cylinders. I didn't think it was horrible for nearing 170k miles.
Did a compression test on my car,and it was 180psi right across .Its a 95 RS with 271K on it.lm thinking its not to bad for what l think is a high millage car?
Last compression test I did which was about a year ago, I was at around 180 in all cylinders. This is with over 3 years of boost so I was quite pleased.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
