oil burn restrictor
nolig2278
oil burn restrictor
Post by nolig2278 »
Does the stock BPT setup need an oil restrictor or is the metal feed line to the turbo already limiting the pressure?
I went from 10/30 mobil 1 extended performance oil to 20/50 and bought a new cheap pcv valve, then saw smoke. Especially after leaving my parking garage. (a little too much oil caused some backup while going down)
Now I am on 5/30 and initially some smoke but seems to be lessening.
Thoughts/suggestions
thanks
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
[url=https://gilon.levinsonltd.com/mx-3.html[/url]
hgallegos915
Re: oil burn restrictor
Post by hgallegos915 »
If this is an ebay turbo chances are you will need to restrict oil flow ALOT.
I even had to restrict it on a real garret turbo I had.
-hec
johnmx3ze
Post by johnmx3ze »
nolig2278 wrote:Does the stock BPT setup need an oil restrictor or is the metal feed line to the turbo already limiting the pressure?
thanks
if ever you need to restrict it and you need an oil restrictor PM me i have a brand new one that i bought for my klze-turbo project and i havent used it ...its stillbrand new and sealed...
nolig2278
Post by nolig2278 »
I have the stock BPT IHI VJ20 Turbo
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
tehbrookzorz
Post by tehbrookzorz »
20w50 seems really thick to me...
Cody
Return to “Forced Induction”
