oil cooler for K-series engines
Collier
Post by Collier »
I was in autozone getting everything I needed to change the oil on my miata and I saw that the oil filters for the mx3 and miata were the same. So in theory, the threads will line up and an oil cooler kit for a miata could work on a mx3.
solo_ryder
Re: oil cooler for K-series engines
Post by solo_ryder »
If you have a 4 cylinder then yea :)
I am sure you can make something work for a v6 too but the v6 doesnt really need to have cool oil, it has a cooler on the oil filter neck that runs to the coolant
Collier
Post by Collier »
I'm pretty sure that it will work on the v6 as well. If the oil filters line up then the oil cooler should as well.
I know the v6 came with one stock but I was thinking that it could probably use some help.
I was working on the principle of colder=better.
