please help find more sites
add them to the post and i will update it in to the top
please tell me what on the site and then the address
and thanks to all that help out
>323/Protege Factory Service Manuals< // http://www.ferdster.com/FSM_PDFS/fsm_pdfs.html << thanks to rusty >>
info// http://en.wikipedia.org/wiki/Mazda_B_engine
info// http://en.wikipedia.org/wiki/Mazda_mx3#Engine
info// http://www.mx-3.com
info// http://www.cargurus.com/Cars/Specs-c571 ... Miata.html
info// http://www.cargurus.com/Cars/Specs-c5712-1993-MX-3.html
parts that interchange info// http://www.erdtonline.com/wiki/index.ph ... lity_Guide read this if you want to find other parts to swap around )
specs// http://www.mx-3.com/brochure/specifications.cfm
trans info// http://www.protegefaq.net/
topspeed calc// http://www.catherineandken.co.uk/sti/tyres.html
bp and bpt motor .... 323
http://sturtevant.com/323gtx/forsale.htm
http://www.mazda323performance.com
http://www.jdmracingmotors.com
gauges / pods
http://www.gaugepods.com/mazda.html ..... gauge pod
http://www.showoffimports.nl/product.ph ... ctid=26884 ..... gauge pod
cam shaft
http://www.horsepowerfreaks.com/perform ... ngine/Cams ( inline 4 - 1.6 and 1.8 )
http://www.alamomotorsports.com/webcam/mazda.html ( inline 4 - 1.6 and 1.8 )
http://www.streetunit.com/Cams_Cam_Gears_s/742.htm
sway bar
http://www.horsepowerfreaks.com/perform ... /Sway_Bars
http://www.templetuning.co.uk/whiteline ... 3694-p.asp
butterfly keys
http://butterflykeys.com/Details.asp?id=559
aftermarket manifolds Turbo manifolds notes and parts
http://www.etdracing.com/escort.html (bp and bpt manifold)
http://www.turbochargers.com/store/inde ... =2a&page=4 ( just parts no Manifolds )
http://www.ssautochrome.com ( just parts no Manifolds )
http://www.etdracing.com/products.html
http://www.corksport.com/?sl=EN
ram air intake parts
http://www.europerformance.co.uk/pages/ ... category=1 ( note if it fits the pipe then it will work )
all parts
http://www.mazda-parts.com ( All things OEM Mazda ) << thanks to wytbishop >>
http://www.jeroentje.nl/index.php?page=home *****
http://www.horsepowerfreaks.com *****
http://www.importperformanceparts.net/ *****
http://www.racinglab.com/
http://www.eautoworks.com
http://v2.showoffimports.nl/home.php?setregion=jp
http://www.autopartswarehouse.com
http://www.autoanything.com/car/mazda/m ... A2772.aspx
http://www.andysautosport.com/mazda/1992_1995_mx_3/
http://www2.partstrain.com
http://www.elementmotorsport.com
http://www.globalperformanceparts.com
http://www.coximport.com/
http://www.sfxperformance.com/
http://www.performancepartswholesale.com/
http://www.speedyperformanceparts.com/
http://www.alfaotto.com ( not many but has some look hard )
http://www.slickcar.com
http://www.thepartsbin.com/ ( oem )
http://www.joetlc.com ( oem )
http://www.autohausaz.com/
http://www.tweakit.net
http://www.awrracing.com/index.php ( aftermarket engine mounts and more )
Alternators
http://www.motorcityreman.com/mazda.html ( aftermarket Alternators 140 amp )
Suspension
http://www.octanemotorsports.com/Mazda- ... index.html
http://www.ksportusa.com/asp/index.asp
http://www.d2racing.com/content/products
clutch and flywheel
http://www.dxdracingclutches.com/home.html
http://www.clutchandflywheel.com/clutch ... mazda.html
http://www.importperformance.com/act/mazda.html#MX3
http://www.awrracing.com/pages/quaife.html
custom trans (gear makers and other internal parts)
http://www.rushgears.com/
http://www.piercemotorsport.com/servlet/Detail?no=33 ( g trans Limited Slip Differential )
http://www.protegegarage.com/1051-product-1051.html ( 3rd and 5th gears 15% harder than stock -g trans- )
Throttle Bodies and Individual Throttle Body Kits
http://www.matrixracing.com
http://extrudabody.com/
http://www.tweakit.net/shop/index.php?c ... f3eaf95b9c
http://www.gude.com
brakes
http://www.xrcbrakes.com
cooling
http://www.daviescraig.com.au/ (electric fans/water pumps)
http://www.a1electric.com/catalog/cat_spal.htm
http://www.wizardcooling.com/ (custom fit Radiators)
computers
http://www.diyautotune.com
http://www.bgsoflex.com/megasquirt.html
http://www.wolfems.com
http://www.importevolution.com
http://www.directignition.com/index.html
http://www.tweakit.net/shop/product_inf ... ucts_id=87"
mass airflow sensor
https://www.rockauto.com/dbphp/mak,MAZDA,1993
body parts
http://www.bodykits.com *****
http://www.zerospec.com *****
http://www.tuning-in.eu/mazda/mazda-mx-3/ *****
http://www.extremedimensions.com/shopdi ... -3%2092-95
http://www.evilyeti.com/
thanks too
Mi|<E
rusty
sites for parts and more
Last edited by cricketol2 on November 26th, 2011, 1:27 pm, edited 57 times in total.
Re: sites for parts and more
site fix
butterfly keys
http://butterflykeys.com/Details.asp?id=559" onclick="window.open(this.href);return false;
butterfly keys
found aftermarket Alternators 140 amp for 300 $
http://www.motorcityreman.com/mazda.html" onclick="window.open(this.href);return false;
All things OEM Mazda at really good prices.
http://www.mazda-parts.com" onclick="window.open(this.href);return false;
up to date and fixed all bad sites ( 4/29/2010 )
FOR BP / BPT
fuel presser regulator psi guide
I actually do know off the top of my head. It's 38-46 psi
There are 2 ports on the pressure reg, low temp raises pressure
to 41 psi and the high temp raises further to 49 psi.
Dont increase the pressure at idle past 46 psi - it causes unwanted
effects.
And also dont argue with me over these values, I dont want to
post the service manual pages.
this is thank to Mi|<E
thanks for the info
if its not for bpt please tell me so i can update it thanks
effects.
thanks for the info
323/Protege Factory Service Manuals GTR / GTX
posted at the top > update <
