How much $$ to fix stereo wiring?
Car Stereo/Alarm Discussions
fowljesse
Post by fowljesse »
The previous owner of my car had a stereo installed, and the left turn signal doesn't work. He said that when they extended the wiring harness, they didn't do a good job. Also, there's a whine (interference), and when I adjust my power mirror, the radio cuts out. It also randomly quits working. It stays on, but there's no sound. It has a fuse block in the engine bay I want to get rid of, too.
Do you guys have an idea of how much it would cost to fix these issues?
Mnemonic
Re: How much $$ to fix stereo wiring?
Post by Mnemonic »
maybe 50 bucks to grab a harness from the junkyard?
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
fowljesse
Post by fowljesse »
I meant how much to have someone else do it, because I know bupkis about it, and electronics hate me :oops:
If it's more than $50, I'll figure it out, and do it myself. The fuse block looks really nice, and I'm hoping someone will take it as partial payment..
Ryan
Post by Ryan »
I also get interference when I adjust my mirrors. Even with the stereo on any voulme, the interference is the same volume :shock:
If you listen to fuzz on AM stations, sometimes you can tune it to your RPM's and listen to your sparks via your stereo :)
So I just don't adjust my mirrors much.
The blinker is an issue though. Trouble shoot it? fuse, bulb, grab a multimeter and check for resistance at different points in the system...
Also, now that I remember, my stereo also used to cut out. still on, still plays, just NO sound. I pulled it all apart and put it back together and even though nothing SEEMED wrong... it worked...
wagZE
Post by wagZE »
If you lived up here Jesse I'd fix it for ya for a twelve pack, the car audio business is so slow up here bro... Alternator whine is due to a poor ground connection 99 out of 100 times. Make your own ground like around on the kick panel & run it to the deck... As per the fuse block just take it out & re wire to the stock radio wires use the12volt.com/vehiclewiring to see what color wire does what. As per the turn signal that you'll have to figure out on your own, I doubt its a fuse or a wire outside of the steering column.
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
fowljesse
Post by fowljesse »
I tried E-mailing, and PMing you about it :? but I guess you didn't get them. I'm up here doing a study again, and would prefer to have you do it over a random audio shop, because I trust you. I'll be in Tacoma the 22nd and 23rd, and then will be here again in 5 days (the 28th, I think). If you can do it any of those days, I'll buy you a 24 pack!
My car is stronger than last time you drove it, and will be even stronger soon 8)
Return to “Car Stereo/Alarm”
