Funny charge light
Posted: October 31st, 2008, 8:17 pm
by NorCalMX3
Okay, so my charge light has become quite sporadic. sometimes when i'm driving, it stays off. more often though, it stays on at a low RPM, but will fade out at a higher rev. does this signify a slowly failing alternator? or maybe just a new belt? the car itself seems to run okay and i haven't had to jump-start it yet.
any advice would be great!
Re: Funny charge light
Posted: November 2nd, 2008, 9:52 am
by lowflyinmx3
Make sure your cables are on tight. My light did that after I changed my battery out and got in a hurry and forgot to tighten them.
Posted: November 5th, 2008, 6:53 pm
by abiba_69
Just to add, make sure the post's and terminals are free of the green or white death. CORROSION. That's a killer.
Posted: November 5th, 2008, 8:35 pm
by NorCalMX3
No corrosion, battery terminals are very clean. I
tightened the terminals on my battery, seemed to help a bit, but the problem still persists.
Posted: November 6th, 2008, 2:51 pm
by ninjajim4
i think its an alternator on the way out. mine is that way too, most especially when it rains for some reason. been like that for liek 2 years.. so far so good
Posted: November 10th, 2008, 9:22 pm
by NorCalMX3
okay so i figured out it is my alternator, the question is now, when i remove the alternator, do i take it out from the top or the bottom? i'm guessing that i have to remove the radiator to get to it. any advice on pulling it would be greatly appreciated. by the way, it's the gs
Posted: November 18th, 2008, 3:56 pm
by ninjajim4
check the shop manual, but i believe you got to take it out from the bottom, removing the AC compressor if you have one (from the mounting, you can leave the lines hooked up). i dont think the radiator needs to come out, but maybe pull the fans if you want extra room
Posted: November 18th, 2008, 7:53 pm
by Daninski
If you have A/C remove the rad and take it from the top. Takes like 10 mins and no crawling under the car. Good time to replace rad hoses and have a look around too.
Posted: November 19th, 2008, 7:26 am
by abiba_69
Congrats on the find. But, what gave you the GO-AHEAD that it's the alternator?
Thanks,
Chris
Posted: November 19th, 2008, 11:39 am
by Mooneggs
abiba_69 wrote:Congrats on the find. But, what gave you the GO-AHEAD that it's the alternator?
his symptoms were classic alternator failing signs
Posted: November 19th, 2008, 3:09 pm
by ninjajim4
Daninski wrote:If you have A/C remove the rad and take it from the top. Takes like 10 mins and no crawling under the car. Good time to replace rad hoses and have a look around too.
i respectfully disagree with mr dan... compressor's only four extra bolts, and you don't have to mess with all the coolant dripping plus extra cost to refill
Posted: November 19th, 2008, 5:12 pm
by FlyVFR
I would replace the alt. It can be removed without taking the rad out. There is only one bolt on bottom.
