Funny charge light
Funny charge light
Okay, so my charge light has become quite sporadic. sometimes when i'm driving, it stays off. more often though, it stays on at a low RPM, but will fade out at a higher rev. does this signify a slowly failing alternator? or maybe just a new belt? the car itself seems to run okay and i haven't had to jump-start it yet.
any advice would be great!
1992 MX-3 GS:
http://www.cardomain.com/ride/2607936
1995 Honda Del Sol (Current Main until KL-ZE Swap):
http://teamsolcal.com/forum/showthread.php?tid=20662
- lowflyinmx3
Re: Funny charge light
Make sure your cables are on tight. My light did that after I changed my battery out and got in a hurry and forgot to tighten them.
Mazda.... What happens in the parking lot, stays in the parking lot
Just to add, make sure the post's and terminals are free of the green or white death. CORROSION. That's a killer.
No corrosion, battery terminals are very clean. I
tightened the terminals on my battery, seemed to help a bit, but the problem still persists.
1992 MX-3 GS:
i think its an alternator on the way out. mine is that way too, most especially when it rains for some reason. been like that for liek 2 years.. so far so good
okay so i figured out it is my alternator, the question is now, when i remove the alternator, do i take it out from the top or the bottom? i'm guessing that i have to remove the radiator to get to it. any advice on pulling it would be greatly appreciated. by the way, it's the gs
1992 MX-3 GS:
check the shop manual, but i believe you got to take it out from the bottom, removing the AC compressor if you have one (from the mounting, you can leave the lines hooked up). i dont think the radiator needs to come out, but maybe pull the fans if you want extra room
If you have A/C remove the rad and take it from the top. Takes like 10 mins and no crawling under the car. Good time to replace rad hoses and have a look around too.
Congrats on the find. But, what gave you the GO-AHEAD that it's the alternator?
Thanks,
Chris
Thanks,
Chris
his symptoms were classic alternator failing signsabiba_69 wrote:Congrats on the find. But, what gave you the GO-AHEAD that it's the alternator?
i respectfully disagree with mr dan... compressor's only four extra bolts, and you don't have to mess with all the coolant dripping plus extra cost to refillDaninski wrote:If you have A/C remove the rad and take it from the top. Takes like 10 mins and no crawling under the car. Good time to replace rad hoses and have a look around too.
- FlyVFR
I would replace the alt. It can be removed without taking the rad out. There is only one bolt on bottom.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
