Correct way to run wire through doors?
Posted: October 25th, 2008, 12:46 pm
I had a component system hooked up in my RS but since I am selling it, I am taking my system out and putting it in the GS. I ran all new 12 Gauge wires through the doors so that I could power both the tweeter and the mids separately. This was a HUGE PITA. I took off the rubber boot thingy that bridges the door to the car and drilled holes through the plastic that holds all the wires. Feeding the wire through that was a pain. Well, now I have to do it all over again on my other car!
Unfortunately, I cracked a rib a week ago, and being the person that I am I spent yesterday starting this rewiring project...and re-injured myself by twisting in an awkward position (the nature of wiring). So now that I have some time on my hands to do nothing but lay in bed,I figured I'd see if anyone had some advice to make this a better/easier wiring process.
How hard is it to re-align the doors after you take them off? My doors shut fine and I have no issues with them, so I would rather not have to mess with them, but getting the boot off of the doors with them attached to the car is quite difficult, let alone trying to drill a hole or carve through the plastic inside it. I could drill a separate hole through the door/car, but that would promote rust and probably damage the wires over time. I decided that 12 Gauge was overkill, so I decided to just get some regular 14gauge outdoor speaker wire, instead of the double shielded stuff I had before. This means that I don't have to drill as big a hole as I did before.
Whats the best way to do this? I know I'm not the first to do this, as I'm only running a mild system (Polk Momo MMC6500)
