I have low or high bass problem.... i turn it up and it sounds horrible (like pass 20 volume level) it is two subs on a 800 w mono sub... need help .....
any thoughts??
Low and high bass
MX3Extreme
Re: Low and high bass
what are the frequency settings at and gain levels? and make sure the mono amplifier is a actual monoblock cause if it isnt and there is a high pass and low pass settings on the amp, then make sure its on lp(low pass)
MX3Extreme
MX3Extreme
the bass booster is at 6 and then gain is like 500 i think and the other nob can't remember that one does it is at .6
- Ryan
gain of 500 sounds wrong that may be your LP filter, if anything. That should be around 100.
It tells you how to set up your amp in the destructions....
this one didn't come with instructions cuss i bought it off someone
- Ryan
I can't find mine at the mo.
Try googling amp settings
thanks.. you know the song elevator and the song what you got haha yeah that bass
- Ryan
Here's a really good one I found, when it comes to comprehension, its not a how-to though.
http://www.teamrocs.com/technical/pages/gains.htm" onclick="window.open(this.href);return false;
I think the general idea is setting the LP to somewhere between 75-100
Bass boost low
Then turn up your speakers to near-distortion, then turn the gain up untill the subs are near distortion. Done.
Bass boost low
thanks i think i have figured it out so it should be good
