Altezza red/pink
Altezza red/pink
Ok so my passenger side tail lights glows pinkish but the drivers side looks alright. I'm thinking maybe the paint around the reflective lenses are fading maybe?
- solo_ryder
Re: Altezza red/pink
Maybe your eyes need to be checked?
Different color bulbs on one side?
Pics?
Pics?
I the camera doesn't pick up the difference and my buddies all say it look different
I'm going to say that you probably have different colors of bulbs on each side. Easiest way to check is to pop the light housings off, take the bulbs out and look at them. If they are infact the same color on both sides, then it could be that the reflective material has water/solar damage or wear and tear of some kind.
Green Machine --1994 MX-3 GS 5-spd-- HEI Ignition Modded
- Dali
mine do the same thing, swapped bulbs around and still looks pink. the plastic is not as red as the rest in the taillights as far as i can tell. nothing i can do with my set.
1993 White gs klze.
Yea I think the inside reflecters have faded a bit. Now how do I fix them? haha they have to be re-painted some how, both of them.
purewhitemp5
install red led bulbs or just plain red bulbs.
