SAFC settings for MX3
war_spider
Post by war_spider »
hallo,
somebody knows the car/sensor settings @ oldschool APEXi SAFC ... for the MX3 EC? same as RX7 FC3s?
-= loud pipes save lifes =-
KL-ZE inside!
solo_ryder
Re: SAFC settings for MX3
Post by solo_ryder »
Dont think anyone here is tuning via SAFC man. If you are doing this you need to mess with the TPS sensor so that it never reads more then 90% throttle when you are WOT. If you are running a SAFC and you go WOT the ecu in the car will not acknowledge the settings of the SAFC and run a pre-determined map that is stored on the ECU..
Best of luck
war_spider
its not for me... i own a FC3s RX-7
and a guy with a MX3 bought my SAFC...
on 16V the same problem as V6? on right sensor it should work.
KL-ZE inside!
fieromx3
Post by fieromx3 »
what u mean? sensor settings like karman, flap and hotwire? i had the safc neo on mine and set it to hotwire
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
hgallegos915
Post by hgallegos915 »
Ive learned that the only WAY and YES ONLY WAY to FUEL tune the mx3, is a wideband and a cosmop adjustable afpr and a walbro pump.
Im getting AWESOME results!!
Im in par with the local stock stis with just a ze and bolt ons.
At WOT Im at 12 afs.. its nice to tune it :D
I noticed that the stock set up isnt well tunned.. it runs like 13 afs 13.5 under wot. or if omething is wrong like 10 afs lol (bad o2s)
Plus you can use the wideband again if u turbo
-hec
