I am now* the proud owner of two mx-3s a 92 rs and gs... i have a slight issue with the GS atm though... i can go from 1st to 2nd and 2nd to third fairly easy ( can has 180k+ ) butttt... when going from 3rd to 2nd... i have to rev match just to get it to go into gear ( with clutch all the way down... this is me just trying to get it into gear coming from third )... im thinking the fool before didn't know how to shift and screwed the pooch for 2nd gear...
Any ideas why it is doing this?
How much yall thinking it will cost to fix?
Worth getting the whole thing rebuilt.. or
Can i just buy a KLZE and mount it to my K8 (http://www.jdmtigerjapanese.com/product ... cts_id=150" onclick="window.open(this.href);return false; ) with little swapping action?
I just replaced the cluth, flywheel, slave cly, and throwout baring and pilot i think as well.
k8 Tranni Problems
The1KingBob
Re: k8 Tranni Problems
anyone :-\
The1KingBob wrote:I am now* the proud owner of two mx-3s a 92 rs and gs... i have a slight issue with the GS atm though... i can go from 1st to 2nd and 2nd to third fairly easy ( can has 180k+ ) butttt... when going from 3rd to 2nd... i have to rev match just to get it to go into gear ( with clutch all the way down... this is me just trying to get it into gear coming from third )... im thinking the fool before didn't know how to shift and screwed the pooch for 2nd gear...
2nd gear syncro is shot. Not easilly fixable. You have to either change the entire shaft (not sure if the 2nd gear syncro is on the input or output shaft) or replace the tranny.
You *can* put a KLZE tranny on a K8, but it wont be matched properly. It uses a taller 4.11:1 ratio that wont be matched well with the stock K8. I don't think anyone has ever tried it, but more likely it'll cause poor performance and may actually decrease the milleage since the motor will have to work harder. It would be best to put that tranny in when you swap to a KL motor.
The1KingBob
Well i am thinking im going to do a BP swap in my RS... and turn this GS into a daily driver... and i think the k8 gets the best gas milage? Either way anyone got a rough range of what it would cost to get a k8 tranni rebuilt? How hard is it to rebuild a tranni myself? Never done it before :-\ not even sure what is needed ahha....
ty for the response
ty for the response
maybe b6 or b8 trannies from a 323 can fit? this came across my mind, i'm not sure if this works.
i have the same problem, it does occassional let me go from 3rd to 2nd but most of the time it wont at all. im just getting a new tranny when i have the funds.
wont fit in the gskenken wrote:maybe b6 or b8 trannies from a 323 can fit? this came across my mind, i'm not sure if this works.
94 mx3 rs
92 mx3 gs curved neck klze SOLD
neli_nael wrote:i have the same problem, it does occassional let me go from 3rd to 2nd but most of the time it wont at all. im just getting a new tranny when i have the funds.
oh...what tranny fits the gs then?
mx6, 626, probe v6 modelskenken wrote:oh...what tranny fits the gs then?
94 mx3 rs
The1KingBob
Anyone got an idea what a 'normal' rebuild tranny off one of those cars cost ( any chance someone knows the actual name for the tranny )
Think i should maybe have it rebuilt?
