still don't know which KL i have
so i bought the engine from a place around my house. I paid 700 for it wwith 35,000 miles. When i brought it home i checked the codes on the block and they where DE codes, but someone said it still could be a ZE, it did not have a cover over the EGR (but did nolt have an EGR either) it has ZE throttle body codes and curved neck. KL01 cams as well. Is there any way that this could still be a ZE? THanks
							92' GS KLDE, Cosmo Racing UDP, CAI, AWR Motor mounts solid, Pheno spacers . interior gutted, MTX Swap, unorthodox racing flywheel/ 4 paddle clutch. short shifter, SRD bushings, brembo cross-drilled rotors, corksport racings red stainless steel lines. megan escort springs, zx2 sturts, whiteline rear sway bar, rear strut bar.
						- Dragyn Vyrus
Re: still don't know which KL i have
it may have the ze throttle body but if the block is de then it most likely all is,
and kl01 cams are in the domestic kl's like the mellenia and the de
I do believe that i am right on this, but i could be wrong...
93 MX-3 ZE-GS - Sold
95 MX-3 RS - Bone stock winter car.
92 JDM turbo MR2 - SSQV, Cusco strut tower bar, ATS intercooler kit, Berk Exhuast, HKS EVC-S
- 2fazed
You could have a Klze.  There's 2 versions.  Straight neck with ze heads, pistons, cams.  And the Curved neck, which varys.  It could have the Ze heads, De pistons, cams.
If you can exchange it with whom you bought it from. Ask for the straight neck Klze.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
						06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
				hgallegos915
seems like a de or a millenia DE
there were two versions of the US millenia..
a DE with curved neck and a ze.
ive myself seen the millenia de.
-hec
