gas tank and float/meter
first things first, how much does the 93 base model mx3 gas tank hold in gallons, and two, do any of you have problems with your gas meter bouncing around? my needle bounces around anywhere from an 8th of a tank to a 4th of a tank. could this be the float in the tank that is messed up, or is it the meter? help please!
Re: gas tank and float/meter
The gas tank holds 50 Liters or 13.2 US Gallons.
There is a hollow plastic floater attached to the fuel pump which indicates
how high the gas is in the tank. When you corner fast the gas sloshes around
and can throw a high or a low reading depending on turn direction. Nothing
to worry about just read your gas guage when the car is on a flat level surface.
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
ill be driving down the interstate and it will do that, here in nebraska there arent really any hills, even when im on a flat surface and not bouncing up and down or turning it will still give me bad readings
