where to buy millenia s injectors
- PWRD_BY_HKS
looked around cant find any web sites... ifound the nissan's but id rather have a direct fit and something i wouldnt have to rewire ...
thanx guys!
thanx guys!
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- solo_ryder
Re: where to buy millenia s injectors
eBay, PT, MX6.com ...
Come on, dont be a n00b. You have been on these boards for awaile, there may just not be any available right now
- Kirk95gs
one set on ebay right now I do belive.
- solo_ryder
They are modded nissans:
http://cgi.ebay.com/ebaymotors/Millenia ... enameZWDVW
keep your eyes peeled, they come up alot
- PWRD_BY_HKS
Yeah but those nissan ones, do you have to rewire anything like splice wires or anything like thatt?
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
in the description its i think it said it was just a drop in, so i dont think it needs wireing.
92 Blaze Red MAZDA Mx3 <GS> ZE, millenia manifold. gutted interior, filled mounts, fidanza fw, act 6puck.
- solo_ryder
It needs wiring, the seller can fill you in on the details
hgallegos915
Those need wiring, cmon dude they are not hard to find. I got mine on ebay cheap.
Nissans are overdoing it if you plan on staying at around 5psi...
actually iw as runnign RICH at idle with the millenias if you dont have msns. I say just get the millenias for safely. the nissans you need stand alone for that. You will have a fucked fuel mileage with the milenias without msns but its worth not frying your engine.
I also suggest while you at it, replace your IM gasket. Turbo seems to like blowing it.
ALSO you will need to PULL the injectors from your STOCK rail.. the millenia rail is different.
Dude why havent you asked me all this.. its s--- i been trough.. its not like Im gonna lie to you and tell you whats wrong for your car :/ you ask the questions here that ive already been trough.. who cares about boosted status in el paso. this is to f*cking get your car running right.. im holding off on mine until i get the correct parts. I dont care to be the only or fastest turbo mx3 in el paso. Thats nothing . and just ask me when you have questions! :/ for some reason i feel as if you think i lie to you.. :/
-hec
- solo_ryder
