Holly Crap my K8 is leaking/burning oil like crazy
- cabriolet
My K8 goes through like 1L of oil these last couple days, although I run alot of highway everyday.
do you guys go through a lot of oil burning / leaking on these k series engines?
* White 92 MX3 GS * +bone stock K8+ NGK Iridium Plugs + 10.2mm Iridium wires + RAZO shift knob + 8000K HID kit + grant steering wheel [wtb] white fenders
- solo_ryder
Re: Holly Crap my K8 is leaking/burning oil like crazy
I dont, but my old motors did. It seems that all older k8s burn oil, usually bad rings and seals that develop over time. There is not a whole lot you can do to fix that unless you get a rebuild or swap the motor but I wouldnt say it is uncommon for the k8 to burn oil
						- mitmaks
if its leaking Id check where leak is at and try to fix it. If it's burning it only thing you can do is rebuild heads or swap to ze, etc.
							Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE  '95 Cobra SVT #2722 '68 Charger R/T 440
				hgallegos915
Dont bother rebuilding the k8. PLEASE
							-hec
- cabriolet
LOL ya it was nvr in my considerationshgallegos915 wrote:Dont bother rebuilding the k8. PLEASE
- fowljesse
Don't be offended if this is obvious, but check the torque on your valve cover bolts. A well respected old skool member here is driving around with his leaking
lol yes indeed! I'm sure checking those or doing a simple valve gasket replacement will fix all my leaking problems... as far as the burning... only time will tell!fowljesse wrote:Don't be offended if this is obvious, but check the torque on your valve cover bolts. A well respected old skool member here is driving around with his leaking
- Custom_V6_Limited_SE
Wow, it's been a long time since I've posted here. I am building/rebuilding a K8. hehe Why you ask? My K8 (189k miles) is burning oil at higher rpms and I'm still in the College of Engineering at USF (No major source of income...). I found a brand new Mazda K8 short block for $200 and I am going with a K8 purely for financial reasons. If nothing else, I will probably have the best running K8 lol
							'93 MX-3 GS SE:My Mods
where did you find that short block for cheap?
mine burns oil pretty good too and drives great so i guess its common for the K8
							93 GS SE - Raspberry metallic. K8 - 2 1/4in exhaust w/Magnaflow street series muffler, Custom intake, Kyb Gr2's w/Apex springs, Full kenwood audio - SOLD
when I still had the K8 mine burned oil about a quart a month or so but it had bout 150k on it, Its common when you get a good number of miles on them.
							Teal 1993 MX3GSZE
I lucked out on it. I was just doing various web searches for K8 rebuild parts and came across an expired ebay auction from a few months back where a guy had 7 brand new K8 short blocks he got from an IRS auction sealed in factory packages for $400. I sent him an e-mail and he said he had one left; but, it wasn't in the package so he gave it to me for $200. It seems to be hardly dirty at all and I think it will be perfect once I clean off the gunk from the factory that protects it... Searching long and hard sometimes does pay off
				hgallegos915
wow a spanking new k8 NICE!
Where do you find these IRS auctions?
Also, my k8 burned oil but then again it was 200k miles old.
No one ever bought it for the measly 150 i was selling locally. it just sits there.. lol
-hec
- cabriolet
I switched to 'mobil 2000' 10w-30 for a week now and it doesn't leak at all
