92 mx3 v6 gs
92 mx3 v6 gs
just bought vehical. the car sputters under hard accel but runs fine otherwise. any ideas of what could cause the sputtering. i have never owned a mazda and i dont know what commonly goes on these cars.
Re: 92 mx3 v6 gs
Make sure there are no cracks in the plastic intake air tube.
Run a few bottles of injector cleaner
Re: 92 mx3 v6 gs
Whats the first thing you alway do or should do when you first buy a used car?
DO A HUGE TUNE UP ON IT!. Fuel filter, air filter, oil, oil filter, spark plugs, spark plug wires, cap and rotor, PCV valve and anything else along the way that looks worn!.
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
Re: 92 mx3 v6 gs
Yeah defenetly man, it sounds like an ignition problem. It needs a tune up. Cant be timing UNLESS timing skipped a tooth but that would be the last thing to check. The conputer auto adj the timing. Spark plugs, cap, wires, oil, filters.
-hec
Re: 92 mx3 v6 gs
thanks for the feedback i know it needs a tune up i was just wonding if there was a common problem with sputtering sorry guys
Re: 92 mx3 v6 gs
I had the exact same thing - fine unless under hard acceleration. Replaced spark plugs and air filter and she runs like a beauty.
Worklog! - updated Jun/26
