Ok now autometer guy tell me that I must install a new fuel sender (3262) in my tank to fit with a autometer fuel level gauge (5816).
http://static.summitracing.com/global/i ... m-421b.pdf
1- I don't find where is the stock fuel sender unit in the workshop manuel ?
2- This is the same parts in the tank for a RS and a GS (RS swaped 2.5) ?
3- I need to remove the fuel tank to acces this sender or is that locate near the fuel pump in the trunk ?
I must finish my custom dash...
Tanks for any help
Need, Help ... Fuel sender in tank
racefear
_ ______________________________ _
MX-3 2.5 KL-ZE, kl-36 ECU, Millenia Intake, Outlaw Phenolic Spacer, Custom CAI, Catco 2 1/2 Hi-Flow Cat, Dual Megan Muffler, Mx3 Flywheel, Rear Strut Bar, Unorthodox UDP, Pacesetter Short Shifter, Cross Drilled Front Disk, Tokiko Blue Shock, H&R Coil, 17 inch white Motegie MR7 with Toyo Tire, Blue Metalic and Full Body Kit.......etc.....
14.61@97 MPH
14.61@97 MPH
Re: Need, Help ... Fuel sender in tank
The fuel level sender is right next to the fuel pump (on the same assembly) and they are both located under the rear seat.
